By gto250swb
#26032 Πιο πολλοι σκυλοπνιχτες σε μια σελιδα πεθαινεις, :s_tongue μονο εκεινο το Καζαντζακης ηταν πραγματικα ωραιο σκαρι.
Παρε και μια φωτο(οχι η καλυτερη) απο το αγαπημενο, :inlove:
By doule
#26240 Σύμφωνα με ελληνικά sites και forums το Blue Star Ithaki, μετά από 14 χρόνια υπηρεσίας στα ελληνικά νερά, πωλήθηκε σε εταιρεία συμφερόντων της Καναδικής Κυβέρνησης προς αντικατάσταση του Princess of Acadia.
By rx8_drifter
#26281 Παρτε ματι εδω
Giant ‘Pieter Schelte’ Caught on Camera [VIDEO]
BY MIKE SCHULER ON OCTOBER 13, 2014
Some new video posted to Youtube gives us a rare look at the massive Pieter Schelte, a unique catamaran-like vessel that will soon be used to remove decommissioned oil rigs in the North Sea.
The footage was recently filmed during sea trials near the Daewoo Shipbuilding and Marine Engineering shipyard in Okpo, South Korea, where the ship is being built for the Swiss-based offshore pipe installation and subsea construction company, Allseas Group.
Pieter Schelte is a single-lift platform installation and decommissioning vessel particularly suited for the removal of large steel jacket-based platforms in the North Sea. It will measure 382 meters long by 124 meters wide and features a 58 meter-wide slot at the bow where horizontal lifting beams will be capable of lifting topsides and jackets up to 48,000 tonnes and 25,000 tonnes, respectively. As you can see in the video, the vessel appears to be nearly fully ballasted, but when in use it will have an operating draft ranging from 10 to 25 meters (32 to 82 feet).
DSME has been building the ship for Allseas since 2010, but its concept dates back to 1987 when it was first developed by Allseas founder Edward Heerema, who has described the project as the biggest bet of his career (it has been rumored to cost $3 billion). Allseas is even already planning a second, larger ship with a lifting capacity up to 50% greater.
So far, footage of the giant Pieter Schelte has been rare and this is the first known video of the ship at sea. Later this year, however, it will be moved to Rotterdam where finally assembly will take place, so something tells me we are about to be seeing a lot more of this thing.
Pieter Schelte Particulars:
Length overall (incl. tilting lift beam and stinger): 477 m (1,565 ft)
Length overall (excl. tilting lift beam and stinger): 382 m (1,253 ft)
Length between perpendiculars: 370 m (1,214 ft)
Breadth: 124 m (407 ft)
Depth to main deck: 30 m (98 ft)
Slot length: 122 m (400 ft)
Slot width: 59 m (194 ft)
Topsides lift capacity: 48,000 t (105,820 kips)
Jacket lift capacity: 25,000 t (55,116 kips)
Stinger length (incl. transition frame): 210 m (690 ft)
Operating draught: 10-25 m (32-82 ft)
Maximum speed: 14 knots
Total installed power: 95,000 kW
Accommodation: 571 persons
Dynamic positioning system: LR DP (AAA), fully redundant Kongsberg K-Pos DP-22 and 2 x cJoy system
Deck cranes: 3 x Pipe transfer cranes of 50 t (110 kips) at 33 m (108 ft), 1 x Special purpose crane of
600 t (1,323 kips) at 20 m (66 ft)
Work stations: Double-joint factory with 5 line-up stations and 2 stations for combined external and internal welding; Main firing line with 6 welding stations for double joints, 1 NDT station and 6 coating stations
Tensioner capacity: 4 x 500 t (4 x 1,102 kips)
Pipe diameters: From 2″ to 68″ OD
Pipe cargo capacity (deck): 27,000 t
Τελευταία επεξεργασία από JasonLouk και 19 Οκτ 2014, 14:00, έχει επεξεργασθεί 2 φορά/ες συνολικά Αιτία: Εδώ βάζουμε όλοκληρο το link του video! (στο έφτιαξα)
By Sam Spade
#26451
gto250swb έγραψε:Πιο πολλοι σκυλοπνιχτες σε μια σελιδα πεθαινεις, :s_tongue μονο εκεινο το Καζαντζακης ηταν πραγματικα ωραιο σκαρι.
Και το Ionian Island ήταν ωραίο σκαρί, ωραιότερο από το αδελφό Galaxy. Κάποτε βρέθηκα μέσα με χοντρά μποφώρια στην Αδριατική, ταξίδευε όμορφα.
doule έγραψε:Σύμφωνα με ελληνικά sites και forums το Blue Star Ithaki, μετά από 14 χρόνια υπηρεσίας στα ελληνικά νερά, πωλήθηκε σε εταιρεία συμφερόντων της Καναδικής Κυβέρνησης προς αντικατάσταση του Princess of Acadia.
Αν είναι αλήθεια, απορώ αν και ποιο βαπόρι θα δώσουν στον διάσημο-για-τις-ποζερομαλακίες-του καπετάνιο του.
By kostis20
#28175 Πώς φτιαχτηκαν τα BLUE STAR 1&2. :inlove:
By TakisB
#43672
#47932 CSCL Globe – World’s largest containership
http://www.hellenicshippingnews.com/csc ... -gl-class/
By Chris
#48171 Είναι το γεράκι της μάλτας στη ζέα τώρα, αν θέλει κανείς να βγάλει φώτος..
By doule
#48185 Νέο πλοίο (Fior Di Levante), από νέα εταιρία (Levante Ferries), στη γραμμή Ζάκυνθος-Κυλλήνη.
By rx8_drifter
#48388 Γαμησε τα :lipseald:
Chris έγραψε:Είναι το γεράκι της μάλτας στη ζέα τώρα, αν θέλει κανείς να βγάλει φώτος..
Ο,τι πειτε
:lol:
By DAP
#48390 ^^
Με ανοιχτα τα "πανια" αραγε πως ειναι;
